getting warnings from diagram disabled structure when different user logs in
I have a piece of code, inside a larger application, which is in a diagram disable structure.  When I run the main vi, no errors or warning.  When a different person logs in and runs the code, a warning pops up stating there are errors inside the disabled piece of code.  You can simply close the warning box and the code runs but I would prefer the warning not popup and cause panic in my operators.  I don't find anything about this issue.
Vickie
(3,170 Views)
Hello vickielfl,
I have a few questions for you to help you troubleshoot this issue:
1. Are you running this application as an executable or just as a VI? If it is an executable, did you build it with debug mode enabled?
2. Under File >> VI Properties >> Execution, do you have the "Allow Debugging" and "Enable automatic error handling" boxes checked?
3. Can you provide a quick screenshot of the error?
Jae
(3,128 Views)
1.  Running a vi (not executable)
2.  Turns out the problem went away the 2nd time the operator opened and ran the code so I couldn't duplicate the error.
Thanks for the reply.
Vickie
(3,101 Views)
You sure these weren't crosslinking warnings?  That could be a subtle, but serious issue.
Bill
CLD
(Mid-Level minion.)
(3,094 Views)
Yes I am sure.
It was a warning saying the code in the disabled diagram was not executable because a tunnel assignment was missing.
(3,092 Views)
@vickielfl wrote:
Yes I am sure.
That's good.  I just had to ask to get that question out of the way.  🙂
Bill
CLD
(Mid-Level minion.)
(3,088 Views)
