graph from power spectrum and butterworth filter
I am newbie in labview, I want to see the power spectrum from the samples sound, I want to see if there are some pattern in those samples.
I use spectral measurement, and then I filtered the samples with butterworth filter. For the output I using waveform graphs.
Before filtered the signal, I got in the x axis the graph between 0-22500 and the data mostly in 0-2500.
I have tried to filtered using these values (fs=1000hz, fl=0.125hz, and fh=500hz) and the graphs almost the same but the axis of the graph is between 0-0,5.
questions:
what is the properties of the x axis? why is different but the graphs are the same?
Do I make the mistake with the program?
(4,635 Views)
Accepted by limavolt
Hi Limavolt,
You are having problem with Bandpass filter VI, this VI generates only the signal value i.e. DBL array. The signal is a cluster.
solution 1: you have to calculate 'dt' using sampling frequency and use the build waveform VI to build a signal is proper scaling.
Normally, dt=Sampling frequency/no. of samples
solution 2: replace butterworth filter VI with filter express VI, this will produce signal which does not require scaling.
HTML tutorial  HTML tutorial
162+ CLDs & 10 CLAs Trained
LabVIEW Training resources
(4,607 Views)
Here is an example of the solution 1 of ramktamu.
I generally try to avoid the Express VIs because they hide so much of what they are doing, but in this case they should be fine.
Lynn
(4,584 Views)
Thank you both of you, you saved my days
I have to learn a lot about this software.
regards
limavolt
(4,577 Views)
For the first solution if you consider using build waveform VI. you can calculate dt as,
For low pass and high pass filter.
dt=fs/fc, where fc=cutoff frequency and fs=sampling frequency
and for bandpass and band stop filter.
dt=fs/((flc+fhc)/2)
(4,557 Views)
Ram,
Where did you get those formulas?
dt = 1/fs
It does not depend on the filter bandwidth. It is the interval between samples and thus depends only on the sample rate.
Lynn
(4,544 Views)
