Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
graph x axis problem
JimJones
Member
03-02-2006
10:55 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Is it possible to get the x axis to be independent of the graph, by this i mean i have a graph generator that varies in speed but i want the x axis which is real time not to be affected by the varing speeds of the graph generator.
0
Kudos
Message
1
of 2
(2,756 Views)
Reply
Re: graph x axis problem
altenbach
Knight of NI
03-02-2006
11:02 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I cannot quite understand what "...varing speeds of the graph generator..." could possibly mean. Can you attach a simple example?
In an nutshell:
If your x-values are not equally spaced, you should use an xy-graph.
If your x-values are equally spaced, you use a regular waveform graph or chart.
LabVIEW Champion
0
Kudos
Message
2
of 2
(2,746 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
