04-29-2021 05:19 AM
Hi! when I try to do an "highlight execution" to try to debug the vi, I find that a green arrow shows up in the loop timer.. I was reading in the forum, and from what I understood it is because there is an error, it's stacked there.. is there a way to solve it? I attach the vi, and the image of the arrow.Immagine 2021-04-29 121417.png
Solved! Go to Solution.
04-29-2021 05:58 AM
The green arrow just means that it's running (i.e. has been called, but hasn't finished yet).
05-01-2021 05:54 AM
but it should only take 1ms to complete and it stay so forever; and it stay stacked even if I run it without highlight execution.. I cant understand why
05-01-2021 10:43 AM
"Stacked"? Do you mean "stuck"?
Did you delete it and try to add it again?
05-03-2021 03:44 AM
I can imagine it's some "wait on ms" and with highlight it's actually too slow so it gets tricked into waiting forever? But it's a guess. Does it work in normal mode?
