green arrow on loop timer
Hi! when I try to do an "highlight execution" to try to debug the vi, I find that a green arrow shows up in the loop timer.. I was reading in the forum, and from what I understood it is because there is an error, it's stacked there.. is there a way to solve it? I attach the vi, and the image of the arrow.Immagine 2021-04-29 121417.pngImmagine 2021-04-29 121417.png
(2,760 Views)
The green arrow just means that it's running (i.e. has been called, but hasn't finished yet).
(2,740 Views)
but it should only take 1ms to complete and it stay so forever; and it stay stacked even if I run it without highlight execution.. I cant understand why
(2,665 Views)
"Stacked"?  Do you mean "stuck"?
Did you delete it and try to add it again?
(2,651 Views)
Accepted by alex8624
I can imagine it's some "wait on ms" and with highlight it's actually too slow so it gets tricked into waiting forever? But it's a guess. Does it work in normal mode?
Qestit Systems
Certified-LabVIEW-Developer
(2,627 Views)
