having problem in IMAQdx
When I choose "Create Labview VI" in Vision assistant and go for"IMAQdx Image Aquisition", i am pompted to manually search the "IMAQdx open camera.vi","snap.vi"and "close camera.vi",which i can't find.I have installed Labview2010,IMAQdx 4.4.
thank you.
(2,914 Views)
Accepted by Automator
According to this page, NI IMAQ 4.4 is not compatible with LabVIEW 2010.
You need to get at least NI IMAQ 4.5, you should be able to get from ni.com/drivers.
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,905 Views)
I had a similar problem. If you don't have a Vision Acquisition License, Labview doesn't show those VIs (even if the IMAQdx is installed).
Cheers
Angel
(2,900 Views)
You cam download and install .exe file at http://joule.ni.com/nidu/cds/view/p/id/2625/lang/en. This should solve your problem.
Sanjoe
(2,872 Views)
