help in the programming of the Hc-sr04 ultrasonic sensor
 why we multibly of 6780 ?
thanks in advance
Message 41 of 42
(869 Views)
I am working on a similar issue but this time using a myDAQ.
I am coming across an error 201025 when trying to run the vi you have supplied above.
I believe this is due to limitations in USB connectivity to the myDAQ, is there any way around this issue?
My Labview knowledge is limited, so any help would be appreciated.
Regards
Bryan
Message 42 of 42
(744 Views)
