hex display to number
thanks alot
Message 11 of 16
(1,002 Views)
Thank you so much!
Message 12 of 16
(903 Views)
@2014spring wrote:
Thank you so much!
To thank a specific post, click the golden kudos button in the lower left of it. That's all you should do in such a case. No need to post anything.
(It is completely useless to add a colloquial one-liner to a long and almost 10 year old thread, because nobody can tell what you are replying to and the correct author that helped you does not get any credit from it.)
Message 13 of 16
(877 Views)
Sorry about my post if that upset you. After I gave him a kudo, I thought I would like to say  "thank you" to him as well.
Message 14 of 16
(854 Views)
The real problem is the lack of any connection to which post you were thanking.  Quoting helps here as well.  But, yes, Kudos are more appreciated.
Message 15 of 16
(847 Views)
(It would take significantly more to upset me. :D)
That was actually just a gentle reminder that "thanks", which are very nice in real life, don't really work well on a forum.. 😉
OTOH, you actually did many things right, for example searching the forum and finding an answer instead of creating a new post. 😄
Message 16 of 16
(834 Views)
