hightlight
Looking at your program, it seems like in the first sequence you are putting a wait in a single sequence between two case structures.
Based on how it is written you code would:
1. Check the initial write (from before the program run button is clicked)
2. If write switch is true then write to serial.
3. If write is false then go to wait and wait for user defined time.
4. Check initial read (from before the program run button is clicked)
5. If read is true then read serial.
6. If read is false then close serial.
In summary, you are only reading your switches once for the first sequence. In order to remedy this, you can place a while loop around the case and wait structures so you can set up a polling of the controls.
Travis-E
Product Marketer
Message 11 of 13
(905 Views)
Hi Travis,
I have tried to use the method you suggested; but it looks not solving my problem. If I use 3 cases case2 and case3 work fine, but if I use only two cases case2 works fine. I don't if I am understanding this thing wrong. I have attached the three cases code.
Message 12 of 13
(882 Views)
Accepted by gltfrs
From looking at your code, you don't have a while loop around your entire event structure so you are only reading your user input one time. Also, you didn't include other sub vis so I cannot run your code to step through it.
Travis-E
Product Marketer
Message 13 of 13
(841 Views)
