how can ı change excel column?
Hi everybody,I am new to labview and activex, I can write data to excel(in a while loop)  but there are 65536 rows in a column and ı want to write data to another column when row finishes.I us excel toolkit but i am not able change excel write numeric vi, succsesfully,if  anyone can help, i will be pleased,Thanks
(i also attach  my vi, but  some sub vi you can not run but it is not important it may help you to see the picture of the program.)
(2,399 Views)
it is a little bit to strange to answer to your own question but i found the answer and i think anyone else can benefit from it.I am attaching the modified calculate location.vi which is in the write numeric.vi that is a part of a excel toolkit.If you change the original with the modified one you can change to columns from which row you want.(inthe example it is 200 but this is optional).Any suggestion, reply, or question i will be pleased to answer.have a nice day.
(2,363 Views)
