how can I make vi run faster?
hi ,
i want to know how can i make the VI run faster . i am using Communication with database .while Loop . case structure .
Message 1 of 37
(4,548 Views)
That information helps nothing, so i'll answer with the only statement i know to be true: Upgrade your computer and server.
(I assume there are much improvements to be done on the code, but since you didn't attach the .vi there's nothing to answer to)
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 37
(4,517 Views)
Remove the communication with the database, that will speed things up.
Message 3 of 37
(4,502 Views)
Taking out the while loop should make your program execute to completion much more quickly.
In all seriousness, nobody has a crystal ball that gives us a copy of your vi. It is impossible to tell what could speed up your application based on the description that you have given.
Message 4 of 37
(4,480 Views)
@Emna20 wrote:
hi ,
What is the rate limiting step? (My guess is the "communication", but who knows? Maybe your top-level loop has a 10s wait ...).
How do you measure the speed? What is it now? What speed do you need?
Your post does not contain any useful information.
Message 5 of 37
(4,450 Views)
It's a bad sign when someone says "the VI".  That might mean that all of the code is in one VI.
Message 6 of 37
(4,429 Views)
Yes, but a large VI has more gravity assist, making free-fall faster. 😄
Message 7 of 37
(4,407 Views)
I though Galileo debunked that idea,
Message 8 of 37
(4,392 Views)
Somebody's never dropped a feather and a brick outside of a vacuum...
GCentral
Message 9 of 37
(4,388 Views)
OTOH, a huge diagram acts like a parachute. 😄
Message 10 of 37
(4,378 Views)
