how can I make vi run faster?
Accepted by topic author Emna20
Here's what I would probably do. No need for the search button, just populate the fields whenever the ID changes. (The indexing is outside the event structure so it also updates once when the loop is entered.)
Message 21 of 37
(1,696 Views)
hi ,
thank you everyone .
if i change the ( ID , Name , Brand , Reference ) in the database when the program is running . this change is not appear in LabVIEW . could you please help me .
Message 22 of 37
(1,662 Views)
@Emna20 wrote:
hi ,
Post your code. It's not clear what advice you took or didn't take... There are a few posted solutions, and some made (reasonable) assumptions. If you use one, we need to know which one.
Message 23 of 37
(1,659 Views)
hi ,
i use the solution posted by  Knight of NI
Message 24 of 37
(1,655 Views)
Altenbach's solution won't continuously update the strings. Only once when started. This made most sense  to us, but apparently isn't what you want.
Move the code that updates the string to the time out case of the event structure (that you need to add). Also wire a reasonable time to the TO terminal...
Message 25 of 37
(1,631 Views)
@Emna20 wrote:
hi ,
If the database actually changes (I mentioned that long ago) your code would be highly flawed because the values in the ring and the values later read from the database would be completely unrelated. You could use my code and add a "refresh" button to re-read the database and place the 2D string array into a shift register and reset the ring items to the new database entries. You cannot necessarily rely that the current ring value corresponds to any particular database entry. What if it valid item 10 is selected and somebody would remove all but 5 items from the database??
LabVIEW is a programming language, so everything you need can be done, you just need to decide what you need.
Message 26 of 37
(1,619 Views)
hi
Could you please explain what you mean in a VI
Message 27 of 37
(1,578 Views)
@Emna20 wrote:
hi
This is a long thread and I "meant" a lot of things. Are you referring to any particular statement?
In any case, I am currently posting by phone and don't have access to a computer.
Message 28 of 37
(1,543 Views)
hi,
i want to know if there is  any other solution for this topic : https://forums.ni.com/t5/LabVIEW/how-can-I-make-vi-run-faster/m-p/3931129#M11171833
Message 29 of 37
(1,518 Views)
What have you tried? Can you post some code?
Message 30 of 37
(1,469 Views)
