how do I create a spreadsheet file with labview
I simply want to create a spreadsheet file. all the comments i have read shows how to create a text file. or read/create from a spreadsheet but is it possible to create this spreadsheet through labview?
Message 1 of 12
(8,991 Views)
Hello Ms Temi,
a spreadsheet file is a txt file,
may be you want to say xls ?
Regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
Message 2 of 12
(8,979 Views)
If you had the Report Generation Toolkit for Microsoft Office, you could create a real Excel spreadsheet file.  The Labview primitives Write to and Read from Spreadsheet file only create and read text files where the data is delimited by a tab (default) or whatever else you want to use (comma is popular).  However there is usually much confusion because Excel will open a tab delimited or comma separated variable (.csv) file and make it look like an xls file.  So which one do you want?  txt, csv, or xls?  The only advantages to a real xls file is the cell formatting and workbook pages.
- tbob
Inventor of the WORM Global
Message 3 of 12
(8,975 Views)
Hi Tinnitus,
Yes I mean an xls (excel file). I have attached a word document that has the section of code that I am having trouble with and explains more in detail what I will like to accomplish.
Thank  you, I appreciate your assistance.
Temi
Message 4 of 12
(8,917 Views)
First dont use a doc to show the screen shot. You can directly attach the image in jpg or png. You can use a write to spread sheet directly to create a excel file but again this is not native excel. You have to use activex or report generation toolkit to create a excel file.
Message 5 of 12
(8,909 Views)
You can use a csv file. MS Excel knows how to open this file. If you are not ging to put graphs and need multipule tabs then csv is fast and easier to use. You can still open the file in MS Excel just like an XLS file.
Tim
GHSP
Message 6 of 12
(8,906 Views)
Accepted by Ms. Temi
Hello Ms. Temi,
When you use a write to spreadsheet module, it automatically creates the file and replaces it by default.  If you want to append to the spreadsheet file then you have to input a boolean variable below the module on "append?".
So you dont need to create the file and then do the write spreadsheet since it only wants the path for the file like: "C:\ Documents and Settings\ User\ Desktop\ spread.txt"
Another way you can do is to write on the path the extension .xls and the icon and everything will run as a excel spreadsheet.
-David
Message 7 of 12
(8,904 Views)
This will create the excel file with the random numbers
17973iEB28EECC9AB8CD2A
Message 8 of 12
(8,903 Views)
Thank you! I got it now
Message 9 of 12
(8,887 Views)
Thanks!
Message 10 of 12
(8,886 Views)
