how do I unlock a vi that is password protected????
If it's your code in all rights, why not just bruteforce the VI?  ("Your" in this case being either you personally or the company you work for)
Message 21 of 24
(3,166 Views)
Brute force could work and is probably not considered "cracking" the protection mechanism. You should be ok and the Department Of Homeland Defense is not going to pull out your tonails and NI likely won't sue. My opinion only. If the password is not really long you could probably brute force with VI Server.
LabVIEW 2012
Message 22 of 24
(3,160 Views)
Accepted by setchmo
Well, we found an older version that I'm working with now to update to the current version and adding my items.
Thanks for all of the help.
Message 23 of 24
(3,125 Views)
Nice solution posted.
Message 24 of 24
(3,017 Views)
