Showing results forĀ
Search instead forĀ
Did you mean:Ā
how do i stop my normal code when the event structer code is running for a traffic light
hello, i have a traffic light and i wanted to add a pedestrian walk to it , i added a event structer to turn the lights to red and the walk to green but , the normal traffic light code run with the event code so how do i stop the normal code when i press the button. please reply fast its a project
Message 1 of 17
(18,368 Views)
I WANT TO ADD a count down on my traffic light for the green and red lights can anyone help me with that?
Message 2 of 17
(18,363 Views)
hi my friend what do you need exacte ? where are you from
CLA
Message 3 of 17
(18,290 Views)
from the middle east(B), anyway, as you can see , I added a pedestrian walk to my code using the event structure and when I press the button the event structure code run but my normal traffic light code runs too at the same time, so i want to pause my normal code when i press the event button and when the event finish i want it to resume from where it stopped, or if u have any other suggestion am hearing you
and i want to add a countdown timer for my red lights and pedestrian walks light but i dont kno how
Message 4 of 17
(18,285 Views)
Accepted by badooro
check if this as you need
CLA
Message 5 of 17
(18,265 Views)
so when I press the button it should finish with false first then do true ya thank you it's good, but the timer isn't I wanted a countdown timer is it possible to do it in Labview?
like a timer until the traffic light changes from red to green or green to red, for each traffic light??
but again thank you so much for the help
Message 6 of 17
(18,245 Views)
you are welcome , just make this as soultion as this is recorded in myfile thanks
CLA
Message 7 of 17
(18,196 Views)
i did but do u have any idea about the countdown?
Message 8 of 17
(18,179 Views)
This feels like homework to me.  Even if it isn't, maybe it will be a learning experience to do that part yourself...
Bill
CLD
(Mid-Level minion.)
Message 9 of 17
(18,170 Views)
can you please help me with the code, due date is 2moro and I have no clue how to do it I tried and tried but I have no experience in LabVIEW just super basic stuff
please sir you might be my last hope
Message 10 of 17
(18,167 Views)
