how to add single element (inside while loop) to itself
I have single element numeric output which is inside while loop. Its value is changing in every while loop iteration. If lets say i want to add values of first ten while loop iterations of that variable.  How can I do that.
See attach image for further clarification.
JK
(4,866 Views)
Accepted by josephkirmani
Hi Joseph,
THINK DATAFLOW!
As values are stored in wires and shift registers (and NOT in any kind of variables) you should use those basic LabVIEW elements:
(4,861 Views)
It is not working with your technique. My value is in the output variable and it changes with every while loop iteration. and I need to add output from all iterations.
Let say in 1 iteration its value is 1.5 and in 2nd iteration its value is 1.2. So after 2 iterations the sum should be 1.5+1.2 = 2.7.  This is what I want to achieve. Hope I make myself clear
(4,852 Views)
Hi Joseph,
how can the value in "output" change on it's own when "output" is just an indicator???
THINK DATAFLOW! Indicators are used just to display values. Then value has to come from some data source!
So my example should be ok, when you use your data source instead of the iterator output in my image…
(4,840 Views)
what do you expect after 10 iterations? we are assuming here with what little information given.
(4,820 Views)
