how to adjust number of shown plots on waveform charts
You did not implement suggestion #2.
Please don't have objects scale with the panel, epsecially during developments. It's just a mess.
Here's a quick draft, see if it works for you.
Message 11 of 14
(1,053 Views)
Oh yes. Actually how can I add a value change to boolean array? And also I could not open your modified VI because I have 2009 version of labview. Could you convert it for me? Thank you for your help.
Egemen
Message 12 of 14
(1,038 Views)
Here is the 2009 version.
You need to read up on the event structure and how to configure events. This is basic stuff!
Start with right-clicking the event structure. Select "edit events handled by this case", the press the [help] button on that dialog.
Message 13 of 14
(1,032 Views)
Thank you very much altenbach. I handled.
Egemen
Message 14 of 14
(1,028 Views)
