how to clear string control
hello,
after writing some input into string control and clicked "Ok" button, how to clear the string control?
Thank Smiley Happy
Message 1 of 13
(7,583 Views)
You can write an empty string into the control using a local variable (requires state machine or similar as architecture) or value-property node (can be "sequenced" using error wire).
Norbert
Norbert
Expert: Geometry
Message 2 of 13
(7,580 Views)
how to write or read string after operation auto clear
Message 3 of 13
(7,509 Views)
Message 4 of 13
(6,725 Views)
Can you clarify your question?
Message 5 of 13
(7,506 Views)
Message 6 of 13
(6,722 Views)
Hope this leads you in the right direction
Derick Mathew
Message 7 of 13
(7,470 Views)
Hope this helps 🙂
Derick Mathew
Message 8 of 13
(7,467 Views)
Can you please explain the method in detail, I have a string control and OK button so whenever I enter something into that string and press OK button the string field need to get cleared .. Can you help me in doing that
Message 9 of 13
(7,157 Views)
If you can try creating new thread along with what you tried would be more better.
-The event structure is required to listen to the OK button event.
-Inside the event strcture you simply needd to pass empty string constant to the value property of string control.
-The image exactly does what you need.
uday
Message 10 of 13
(7,155 Views)
