how to clear string control
@DerickMathew wrote:
Hope this helps 🙂
A local variable is highly preferred here over a value property node. You can enforce execution order by placing the empty string diagram constant inside the inner sequence frame.
We need to see the rest of the code to decide if we even need an event structure. If the code is a proper state machine, the string should be cleared once it is processed in the respective state.
Message 11 of 13
(1,839 Views)
This was my starting with LabVIEW
Message 12 of 13
(861 Views)
Welcome back after so many years 😄
Message 13 of 13
(830 Views)
