how to continuously write integer at every one houre in csv file with header 20' 40' 45'
Dear All
attached vi is to count no of container moved on ship accordingly to size like 20'/40' or 45'. i want to save its count value on hourly basis in xls or csv file. next day new csv file should be open to record same data.
(2,827 Views)
So many parallel loops that all do the exact same thing!  You can easily combine all of those into a single loop and eliminate most of your local variables.
Use the Elapsed Time function.  It will make your life easier.
(2,803 Views)
As Tim's said, your code is orders of magnitude too complex because of duplicate code. Please re-think!
Your timer loop will not work, because you are trying to save when the "seconds" is 59. This sill be once every minute (not every hour!) and about 10x in a row (if the loop spins with a 100ms period). Yes, the elapsed time express VI will work.
I am not sure what you mean by "record same data" I assume you want to record "new data". Should the new data overwrite the old data or should it append to the same file?
(2,773 Views)
