how to convert ascii character to decimal integer
I made constant at one end of the type cast block and wrote 'A' then at the other ending I wired a numeric indicator and it displayed on the frontpanel a number from 8 digits !
Message 11 of 17
(2,032 Views)
Message 12 of 17
(2,031 Views)
This is insufficient information to describe the problem. typecast has two inputs and one output. Please attach a small VI.
Message 13 of 17
(2,027 Views)
here it's
Message 14 of 17
(2,020 Views)
There are many things wrong with this. You try to typecast a single character (8bits) to a I32 numeric (32 bits). This makes absolutely no sense!
(For efficiency, typecast has no error output, so it cannot tell you when it receives garbage).
Message 15 of 17
(2,017 Views)
i coverted the represntation to U8 instead of I 32  and it didnot work !
Message 16 of 17
(2,000 Views)
You didn't convert the data to a U8.  You typecast it to an I32 then coerced it into the U8 indicator.
You need to right click the constant wired into the top of the typecast function and change the representation U8.
That is what Apok showed you in message #2.  You already marked his message as the solution, so I don't understand why you are still struggling with this.
Message 17 of 17
(1,996 Views)
