how to convert "True" string to boolean
Hi All,
I've strings as "True" & "False". I want to convert to boolean so that I can change the value of check box control.
Thanks & Regards,
Shrinivas
Message 1 of 17
(25,814 Views)
Hi Shrini,
simply compare for equality with a string constant "TRUE" (maybe do some upper- or lowercase conversion before for easier string handling...)!
Message 2 of 17
(25,814 Views)
Thanks for solution. Can we convert it using TypeCast or by another way?
Shrinivas
Message 3 of 17
(25,812 Views)
You cant use type cast. Type cast will change it to boolean no doubt but not to true and false respectively. Gerdw's solution is simple isnt it?
Message Edited by muks on 08-05-2009 03:09 PM
Message 4 of 17
(25,806 Views)
You could do something as simple as a case structure 🙂 This has a case-insensitive option on the right click menu.
Message Edited by macaba on 08-05-2009 04:40 AM
Message 5 of 17
(25,804 Views)
Message 6 of 17
(25,800 Views)
A rudelberg one.....:smileyvery-happy:
Message 7 of 17
(25,796 Views)
Haha muks- isn't LabVIEW great; it tempts you to overcomplicate things!!
Message 8 of 17
(25,793 Views)
Absolutely............... :smileyvery-happy:
Message 9 of 17
(25,789 Views)
Lol  :smileyvery-happy:
Message 10 of 17
(25,779 Views)
