how to convert square waves to a physical data
No. The sensor output is still 12 V and its internal resistance is less than the 2200 ohms so you would still give overvoltage to the DAQ input. To do something like that you should probably use a comparator with w 5 V output. Then you could use the counter as you have been wanting to do.
Lynn
Message 31 of 37
(1,339 Views)
This time i run the cod in attachment and after a while this error comes;
What can be the reason?
Message 32 of 37
(1,324 Views)
This time i used voltage regulator as seen in attachment
Message 33 of 37
(1,319 Views)
That will not work.  Find someone who understands electronics and ask them to build a suitable signal conditioning circuit for you.
Lynn
Message 34 of 37
(1,310 Views)
With all of your random circuits and programming attempts, I would not be a bit surprised if you haven't already destroyed DAQ device. DISCONNECT out and do not connect until you have a functional signal conditioning setup that you verify with an oscilloscope. Then, if the code does not work, you can consider getting a new card.
Message 35 of 37
(1,297 Views)
Is that the right block diagram for counter terminal?Because when i run it seems like it is running forever and push the stop button the view is not changing.
Please help
Regards
Message 36 of 37
(1,264 Views)
Sgirgin,
That block diagram looks fine for a Counter Input task, but like was said before, there's a good possibility that your DAQ card may be damaged at this point.
Have you verified your signal using an oscilloscope?
Ty Prather
Technical Marketing Specialist
Message 37 of 37
(1,247 Views)
