how to count, how many knobs are created in this
hi everyone, i want to ask you simple but maybe complicated, how we can count that how many knobs are present in this string array at run time.
Message 1 of 9
(3,629 Views)
Accepted by sam67
use "Array Size"
Certified LabVIEW Architect
Message 2 of 9
(3,604 Views)
Thanks but i already did.
Now i want to create truth table combination depends on input like, if one input then just two combination 0 and 1 and if two input then combinations are 00, 10, 01, 11 and the inputs are N so it creates depends on input number
Message 3 of 9
(3,593 Views)
Hi sam,
There is no "string array": it's an array of clusters of [DBL, string]…
Please note there is a difference between the number of array elements and the number of the visible array elements (aka number of visible rows/columns)!
And what is the problem?
Did you search this forum for "combinations"?
Message 4 of 9
(3,586 Views)
Hi GerdW, I already searched but i didnt find.
I just need combination of truth table according to given input. 1 input make 2 combination and 2 input make 4 combinations and Nth input make Nth combinations.
Message 5 of 9
(3,579 Views)
Accepted by sam67
Hi sam,
search more…
Just to give an idea:
The "magic" is hidden behind the gray box.
(All you need is to "add" some rows/columns to the array stored in the shift register. It's a nice lesson to learn array handling in LabVIEW!)
Btw. that is not a "truth table", it's just a table with all possible combinations of 0 and 1…
Message 6 of 9
(3,552 Views)
Thanks man, well i will try.
Message 7 of 9
(3,547 Views)
@GerdW wrote:
Hi sam,
search more…
I tried but hidden part contain logic that i need, if possible show me
Message 8 of 9
(3,530 Views)
Hi sam,
What have you tried? Where are you stuck?
Why don't you attach your VI?
if possible show me
Not possible, I didn't save the VI.
Start with a sheet of paper. Draw the starting array of [0, 1]. Now where do you need to add a column/row with another pair of 0 and 1? How do you need to write the resulting array for the first iteration? Is there an algorithm you need to apply? And the last step: how to you reproduce that algorithm using LabVIEW's array functions?
Message 9 of 9
(3,527 Views)
