how to create new worksheet in excel without using report generation toolkit
    Im trying to create an excel file with 8 worksheets. I'm currently using the write to spreadsheet file vi for this. But how do i create multiple worksheets in an excel file without using the NI's Report generation toolkit module?
Regards
Jay
(3,579 Views)
Accepted by Jay_Ram
You can use the property nodes with selected class as Activex Excel and create all the Excell tools. Check out the example attached.
NizZ
(Give Kudos to Good Answers, Mark it as a Solution if your problem is Solved;))
(3,553 Views)
Hi!
You can also check out this and thisSmiley Happy
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
(3,549 Views)
Thanks Nizz... Thats exatly what i wanted.
Regards
Jay
(3,540 Views)
