how to display array values on indicators
hello friends,
Im working on project SCADA automatic irrigation system in which i have used 4 sensors and ARM controller,
i m able to display all my values on array in labview but i would like to show them on indicators(temp, tank etc)
please tell the detailed procedure or steps which need to be done as im a begineer.
Thank you
Message 1 of 41
(7,792 Views)
  1. Learn to make a VI Snippet or, at least, a screenshot without a camera 😄
  2. Use Scan From String wired rom the output of the VISA Read (this assumes the T, L, H, and W will always be in the response)
Jim
Message 2 of 41
(7,771 Views)
sorry but if i use string scan then its display message  string not in expected format
i need a procedure which will follow my spreadsheet string to array block
thankyou
Message 3 of 41
(7,739 Views)
You were given a procedure. Show what you did. Do NOT post an image from your phone.
Also, you should not be using Bytes at Serial Port when you have enabled a termination character with the VISA Configure Serial Port.
Message 4 of 41
(7,724 Views)
if not bytes then what is supposed to be used
Message 5 of 41
(7,714 Views)
You just use some arbitrarily high byte count. The read will automatically terminate when the termination character is detected.
I would suggest doing a dummy read before entering the while loop. This would eliminate a partial string. Of you still get an error, stick a probe or indicator on the string output of the VISA Read and attach the result. Just to verify that what you posted in your stray image is what you are passing to the scan from string.
Message 6 of 41
(7,697 Views)
sorry sir,
but its still showing message an input parameter is invalid.
can you please suggest any other programming to read the data.
you can tell me step by step procedure.
 smiply i want to show my sensor outputs on indicators, im using rs232 to usb port.
Message 7 of 41
(7,685 Views)
You marked your question as solved so I guess you found the error and fixed it.
Message 8 of 41
(7,668 Views)
sorry sir,
i haven't yet found the solution.. by mistake its be marked as accepted soln.
thankyou
Message 9 of 41
(7,651 Views)
You should click on Options to unmark the question as solved.
Did you do as I asked and create an indicator or probe the output of the VISA Read. The Scan from String should work. If you create an indicator, right click on it and enable \ Codes Display to see if there are extra characters. Post an image of the front panel with the indicator sized large enough to show the entire string.
Message 10 of 41
(7,642 Views)
