how to display computer time in labview
I wanna relate system time with my VI. I mean I can show what system time when I start and end VI. For example, I start my VI at 1pm and end it at 1:10. This info can be told by Labview? Real time module seems to work in this way but I am not sure. Does any one has this experience?
(23,453 Views)
I'm not sure I understand what you're asking, and what the Realtime Module has to do with this. The Get Date/Time in Seconds or the Get Date/Time String will return the time.
(23,450 Views)
Accepted by hxw
Here is an illustration of what fc mentioned.
You can extract the values using clusters.
(23,438 Views)
Thanks for your reply. The zerotolerance's reply is helpful. Thanks.
(23,393 Views)
I'm wondering what can I do for this system to make the time and date in the graph match the current time and date on the computer if you can help me
(13,440 Views)
1. Start a separate thread, your question is not related
2. Attach your vi
3. Do not use the DAQ assistant or dynamic data type, you do not have control of what is going on.
4. I think there is no timing data associated with your dynamic data wire.
(13,431 Views)
