07-06-2005 09:04 AM
07-06-2005 02:58 PM - edited 07-06-2005 02:58 PM
Message Edited by rolfk on 07-06-2005 02:58 PM
07-07-2005 07:57 AM
07-07-2005 09:16 AM
07-07-2005 08:22 PM
07-08-2005 04:20 AM
07-13-2005 09:55 PM
07-14-2005 10:54 PM
Hello! The parameters of your VI should have nothing to do with whether or not the front panel is visible (unless of course the application crashes before it can execute the VI-turned-DLL). There is no problem having a DLL without any inputs or outputs, so none are necessary. As for the type mismatch between a value and a pointer, that's a whole other issue.
Getting back to showing the front panel, I will have to echo Rolf again: make sure that you are not removing the front panel when building your application. Front panel removal is the default setting which requires that you change it. You should change this by going to the VI Settings tab in the LabVIEW build configuration window and changing the "Remove front panel" option to NO.
Kind Regards,
07-17-2005 08:17 AM
07-18-2005 11:50 AM
