 eultof
			eultof
			07-05-2007 01:03 PM
07-16-2007 03:46 AM
07-16-2007 04:00 AM
Thanks for your reply !
I will try this as soon as my PC will re-accept to work with NI-Motion.... I started with 1 pb and now I have a 2nd... I let you now
 sppelletier
			sppelletier
			12-01-2008 12:49 PM
Hello, I'm using a 7604 motor driver and I have 3 stepper motors. I want to disable on axis momentary in my process. I've tried to use the Enable Axes.flx but I only can disable an axis. I need to initialize the controller with initialize controller.flx in order to get all my axis enable. I've tried to play with the PID setting, but it didn't change anything. Am I using the right vi? Thank you,
