how to ger current user's Downloads folder
hi,
I'm looking for a simple way to get the path to current user's Windows Downloads folder.
The Get System Directory has only Documents and Desktop no Downloads...
Message 1 of 9
(5,335 Views)
I believe that the native support for Windows Environment Variables isn't correct, so I use them through SystemExec, instead.  Using the environment variables, I believe you can concatenate a path to the download folder.
Bill
CLD
(Mid-Level minion.)
Message 2 of 9
(5,331 Views)
This seems to work just fine on my Windows 10 computer.
Message 3 of 9
(5,297 Views)
if you use English yes, I'm working in company with some PCs in German so the name will be language dependent. That's the reason why you get user's documents with Get System Directory not by hardcoded string...
Message 4 of 9
(5,268 Views)
Accepted by tcie
you can get it thru registry:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders\{374DE290-123F-4565-9164-39C4925E467B}
I know, the name of the key sound funny but it can be universal but not 100%...
Message 5 of 9
(5,262 Views)
I believe two choices are swapped.
Bill
CLD
(Mid-Level minion.)
Message 6 of 9
(5,247 Views)
I don't understand Bill's comment.  I use a method similar to crossrulz's, but I start at User Home, so it's slightly simpler:
Message 7 of 9
(5,178 Views)
still it works only if the target user is configured in English, use registry key
Message 8 of 9
(5,167 Views)
Apparently I don't understand it, either, because I looked through all the choices and couldn't figure out what i was talking about!
Bill
CLD
(Mid-Level minion.)
Message 9 of 9
(5,152 Views)
