10-22-2020 09:08 AM
hi,
I'm looking for a simple way to get the path to current user's Windows Downloads folder.
The Get System Directory has only Documents and Desktop no Downloads...
Solved! Go to Solution.
10-22-2020 09:27 AM
I believe that the native support for Windows Environment Variables isn't correct, so I use them through SystemExec, instead. Using the environment variables, I believe you can concatenate a path to the download folder.
10-22-2020 11:28 AM - edited 10-22-2020 11:28 AM
This seems to work just fine on my Windows 10 computer.
10-22-2020 12:19 PM
if you use English yes, I'm working in company with some PCs in German so the name will be language dependent. That's the reason why you get user's documents with Get System Directory not by hardcoded string...
10-22-2020 12:38 PM - edited 10-22-2020 12:44 PM
you can get it thru registry:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders\{374DE290-123F-4565-9164-39C4925E467B}
I know, the name of the key sound funny but it can be universal but not 100%...
10-22-2020 01:03 PM
I believe two choices are swapped.
10-24-2020 10:07 AM
I don't understand Bill's comment. I use a method similar to crossrulz's, but I start at User Home, so it's slightly simpler:
Bob Schor
10-24-2020 03:14 PM
still it works only if the target user is configured in English, use registry key
10-24-2020 09:03 PM
Bob Schor
Apparently I don't understand it, either, because I looked through all the choices and couldn't figure out what i was talking about!
