how to get and display max number
hi
i want to get and display max number if i move slider up/down and should be reset if i press button.
Message 1 of 14
(7,931 Views)
Max number of what?  Two values? An array?
On array palette, there is an Array Max & Min VI.
On the comparison palette, there is a Min/Max function for comparing two numbers.
Can you be more specific?  Show some code.
aputman
Message 2 of 14
(7,919 Views)
Show us the code that you have so far for this.  Show us the slider along with its range.  Show us your approximate front panel layout.
This is a learning/teaching experience and not just a free code sight.  Are those your only requirements?  How quickly should it read the slider value?  How will this code exit as the requirements so far, only offer a reset option and not a Stop?
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 3 of 14
(7,914 Views)
LOL this is the way he operates.  Extracting info is like extracting a tooth.  I have my own idiosyncrasies when asking a question:  Like I always have incredible amounts of info - except what the forum needs to t-shoot the problem.  Go figure.
Soon enough, we will have something to work with.  🙂
Bill
CLD
(Mid-Level minion.)
Message 4 of 14
(7,903 Views)
  • I have done this just want more that indicator should be reset when i press momentary button.
Message 5 of 14
(7,892 Views)
When you press the button, the loop stops.  So after the loop, you can write a value to the indicator or you can create an invoke node for the indicator (Reinit to Default).
aputman
Message 6 of 14
(7,881 Views)
Hi Asif,
All you need are:
- a shift register
- the MinMax function
- a select function, connected to your "reset" button
- a numeric constant to set the default max value
Done!
Edit:
Just saw your latest message: You're half way done!
You might have a look at the Pt-By-Pt-MinMax function!
Message 7 of 14
(7,880 Views)
Then add the button and use a Select? function to set the max to 0 when the button is TRUE and keep the max value when FALSE.  You could also use a Case Structure so that the Max & Min is not ran at all when the button is TRUE and you just wire the current value through for the max value.
GCentral
Message 8 of 14
(7,875 Views)
If by "reset the indicator" you mean to reset the state of the button (on or off), change the mechanical action of the button to be a latch rather than a switch.  This is done on the front panel by right clicking the button.
aputman
Message 9 of 14
(7,873 Views)
cant do that. i want that code should start getting max value again from now after i press press any button.
Message 10 of 14
(7,821 Views)
