how to give complete access to the port of laptop
Hello! I need help.
I am receiving data using xbee connected to laptop port. The problem is with baud rate increasing, the receiving time does not increase as it be.
My Instructor told me that your com port does not give complete space to your software(LabVIEW) .My question is how to give complete access of com port to LabVIEW? Kindly help....
Message 1 of 15
(6,359 Views)
Who's baud rate is changing?  Should the baud rate be changing?
Message 2 of 15
(6,351 Views)
We have checked the xbee sending data and receiving data by setting baud rate 115200.In this it takes 8 sec to receive an array of 3000 elements properly. But I want to give my port complete allocation for data receiving so that I can minimize the receiving time.
Message 3 of 15
(6,321 Views)
What does that sentence even mean?
You say 3000 elements.  What makes up an "element"?  Is that bytes?  Or is that several bytes to an element?  Do you mean you need to increase the receive buffer of the serial port?
Message 4 of 15
(6,318 Views)
Give us your VI so we know what you have so far.  You should also better describe the format of the data coming through the XBee.
At 115200, you should be able to send about 92kB of data in 8 seconds (assuming a full stream of data).  So how is the protocol working?  Do you have to request the data first?  Or is the data coming in at a steady rate (like a data point every 1ms)?
Message 5 of 15
(6,300 Views)
One element means that it consist of one byte. So 3000 elements means 3000bytes to be send after 8 seconds.
Message 6 of 15
(6,262 Views)
Accepted by topic author ZohaibRamzane
Here is my vi..... I have set the Baud Rate 115200.But in labview If i receive the data and plot it, it plots accurately after 8sec. But i set the sending time less than 8sec,it does not plot accurately.
Message 7 of 15
(6,251 Views)
What do you mean by "set the sending time"?  I don't see anything that resembles that in your code.
Also odd is that you set your timeout value for your serial port to 120 seconds.  That means if for some reason you have a communication problem (disconnected cable?), it'll take you 2 minutes before the VISA read comes back and says it did not get the data.
What is the purpose of all of your code outside the biggest while loop where you read a measurement file?  That is only going to happen once.  Then you pass all the data to assorted small whileloops that run as fast as they can working on the same data every iteration and either passing it to a subVI if the boolean is true, or doing absolutely nothing if the boolean is false.
Message 8 of 15
(6,241 Views)
You point out the valid point. Actyally what I am receiving in upper loop, I write it to the measurement file.This measurement file is updated its data after 8 seconds. These 8 seconds have been set on sending side in coding of microcontroller.
Actually, I want to read this measurement file and want to perform some analysis on it. This analysis has been performed by the subvis outside the bigger while loop.
Now there is another problem. The problem is after runnunig the program , the upper big loop runs and update write to measure file after 8 seconds. But the read from measurement file only reads the updated file only once not always when I push the subvis button.
I want to read the new data every time as it has been updated every 8 sec.
Kindly check where is the data flow problem and how can I resolve it.Thankyou
Message 9 of 15
(6,210 Views)
Please reply. I need to fix it right now....
Message 10 of 15
(6,199 Views)
