how to insert delay in array?
in my program i need to send array for control 5 servo motors , but i need to send them with delay between each number, it  suppose to control pick and place robot, any idea ?
is it possible to apply delay within array? its urgent thanks
Message 1 of 41
(6,944 Views)
I get the feeling I am missing something but here you go.
LabVIEW 2012
Message 2 of 41
(6,928 Views)
Hi thanks for replay , but actually sir i dun think that it works , let me show you my block diagram then you can help better , thanks for your help sir
Message 3 of 41
(6,922 Views)
I need delay between arrays, for instance if i send 45 56 78 87 54 for my servo motors (there are five servo motor ),  i need delay between this number, if is essential I can make video that how this robot works (working not properly) for better understandgin,
Message 4 of 41
(6,921 Views)
@erfan wrote:
I need delay between arrays, for instance if i send 45 56 78 87 54 for my servo motors (there are five servo motor ),  i need delay between this number,..,
Your statements are confusing and conflicting. You talk about "this number" but show five numbers. Do you need delays between arrays (as you just said and as your code already does) or delays between the elements of the array?
If you need a delay between the elements, you need to add a small inner FOR loop containing the write node and autoindex over the blue 1D array, similar to steve's suggestion..
If this is not the solution, you need to be much clearer in your description, for example describe in detail how the delay should look, e.g.:
  •  45 56 78 87 54 delay
  •  or 45 delay 56 delay 78 delay  87 delay  54 delay
  • or something esle
Message 5 of 41
(6,912 Views)
Hi i need delay like 45 delay 55 delay 55 delay and so on, between element
Message 6 of 41
(6,903 Views)
So, did you try what I suggested above? Any problems?
Message 7 of 41
(6,900 Views)
I uses vi like this for a stepper motor
I forgot in this the stop button, but it worked well for me.
Regards
Message 8 of 41
(6,885 Views)
hi,
i think Steve's suggest is a good ideal and it can work well.
you can try it.
i used this structure to control my step motor 4 years ago.
Message 9 of 41
(6,875 Views)
hi i have followed the suggestion but it doesn't work , here is my program which I attached it , do you have any idea how to apply delay between each element of arrays?  I send these arrays for servo motors of my robot, but I dun want that motors move simeltanusly, I need delay between each movement.
thanks
Message 10 of 41
(6,838 Views)
