how to insert delay in array?
Hi erfan,
A random thought, why have you disabled the termination character? Try to remove the False constant wired to the Enable Termination Char terminal of the VISA configure serial port function and check whether it is working or not.
Nitzz
(Give kudos to good Answers, Mark it as a Solution if your problem is Solved:smileywink:)
Message 21 of 41
(3,307 Views)
Got your point now. Thanks to Arc82s post:)  Just check the attached VI. It must work fine.
Nitzz
Message 22 of 41
(3,306 Views)
If that program is not working, check this simple example, your doubt will be cleared.
Nitzz
Message 23 of 41
(3,302 Views)
Hi erfan,
Does this help you?
Nitzz
Message 24 of 41
(3,289 Views)
i can't look your VIs and also can't make an example, since there is no LabVIEW in this computer.
but i think NITZZ had solve the problem.
Message 25 of 41
(3,286 Views)
Thank you all for your help and support, now I am in my college while I get home I check the robot, hope its work and i wil be able to hit the good mark for my final year project, thanks
Message 26 of 41
(3,277 Views)
Hi nitzz I dun understand that what you add here? can you tell me ? but still it does not work.
I need more help, I said I need to insert delay between elements of array and I need numeric controller to controll that desire delay, but I can't see in the attachment. can you add again and upload it thanks man
Message 27 of 41
(3,250 Views)
here is your example, but i dun think that it wroks the way that i want. I explain my demand in this vi
tnx
Message 28 of 41
(3,248 Views)
Hi erfan,
Now I really don't understand what exactly are you trying to do. What i understood from your previous posts was that, you need each element from the 2D array one by one with a delay between each. ie, 255 Delay 38 Delay 42 Delay 65 Delay 220 and similarly the next row 255 Delay 75 Delay 83 Delay 49 Delay 220 and so on. Thats what the example VI is doing.
If it is something else you want it to do, kindly explain it to me. I'll try to change the example for you. If you have run the example VI you must have noticed that the To VISA indicator gets the values one by one with a delay of 1000 ms. If you chage that 1000 to 2000 the values will come in 2000 delay. May be you can run the example once again and make sure, this is not what you want.
Nitzz
(Kudos are always Welcome;))
Message 29 of 41
(3,228 Views)
Thanks Nitzz let me run the example, now I need to connect the sub vi which is search , then see how it works.
Message 30 of 41
(3,222 Views)
