how to insert delay in array?
Hi erfan,
Check out the attached vi. I have added a timeout event and wired a 10ms to its timeout terminal. There is not need of two wait timers inside the for loop. I couldn't run your vi as the Sub VI was not attached. But still, I think this must work. Let me know if you have anymore queries.
Nitzz
(Give kudos to good Answers, Mark it as a Solution if your problem is Solved;))
Message 11 of 41
(3,602 Views)
I for sure i give you kudos this is enough that you reply my msg in this difficult situation hahaha, let me check now and let you know the result, thanks
Message 12 of 41
(3,597 Views)
By the way I can't see any changing , what did you do ?
Message 13 of 41
(3,596 Views)
Hi ,
Can you attach both the VIs? I mean the Sub VI also.Then i can run it and check it well.. I had added a timeout case in your event structure and wired a timeout of 10ms in your code. Did you see any difference while running it?
Nitzz
(Give kudos to good Answers, Mark it as a Solution if your problem is Solved:smileywink:)
Message 14 of 41
(3,594 Views)
I haven't check yet now I am connecting the usb to check , ok let me check , I have attached the sub vi, thanks
Message 15 of 41
(3,588 Views)
I checked now it doesn't change , still not working properly. any idea ?
Message 16 of 41
(3,585 Views)
i think you should read the technical manual and make sure the VISA configure is in right set.
and i suggest you put the VISA configure and close VISA outside the while loop.
Message 17 of 41
(3,571 Views)
Hi Arc thanks for your advise, actually the visa workes well only the problem here is arrays sending together and it cause all motors move together, can you tell me whats difference that I put visa outside the loop ? I will try that to see the difference thanks
Message 18 of 41
(3,560 Views)
you mean the array like "255 45 56 78 87 54 220" is control 5 motors? and 255 is the handshaking, 220 means the end of this control?
if so, i think you should send it like "255", delay, "45", delay, "56", delay, "78", delay, "87", delay, "54", delay, "220".
Message 19 of 41
(3,526 Views)
Yeap but how to do that ?
Message 20 of 41
(3,524 Views)
