how to make labview real time understand sequence context
Does anyone know how to make Labview RT to understand teststand sequence context? My sequence context is defined as "TS.SequenceContext" as the screenshot in the attachment.
If we need to point a VI for this Sequence Context then which VI from teststand to use? and do we need to add this VI to the Labview Projectr Explorer in RT System to build the project?
I'm using Labview 2009 and teststand 4.2.1.
Thank you very much
(2,216 Views)
Accepted by Triple_H
LabVIEW RT does not support ActiveX which is required for TestStand.
(2,197 Views)
