how to plot datetime against temperature in waveform chart
Hi Kyle,
sorry for late response.
@K Smith wrote:
Try extending the Chart History Length by right clicking the chart and selecting "Chart History Length."  By default the chart is set to 1024 points to display then the chart shifts, try extending this to the point where you can see your entire sample.  Then set the leftmost to 0secs.
Kyle
I don't think I understood this but finally i have found some solution.
Data si still updating from right to left side, but i think that is not big problem 🙂
Thank You for all your help and time!
Message 11 of 14
(1,546 Views)
Try changing the chart to a sweep update mode.  This will always start from left to right instead of pointing to this first instance in time correlating to your data and then auto scaling the x axis to that point.
You can change it by right clicking, going to properties, appearance tab, and Update Mode>Sweep.
Another way you could achieve this is by writing to the offset property node to set your x axis to the first data point as soon as it starts plotting.
Kyle
Regional Account Manager
NI
Message 12 of 14
(1,540 Views)
Yes, this works, but i cannot use sweep update mode.
What should I write to the offset property node?
Message 13 of 14
(1,524 Views)
Hi Tukan,
I think that there is a way for you to accomplish what you want without adding a property node. If you change the chart update mode to scope chart it will do what youy want it to do.
You can change it by right clicking on the chart, going to properties, appearance tab, and Update Mode>Scope Chart.
Perry S.
ni.com/support
Message 14 of 14
(1,508 Views)
