how to plot two xy graph in one xy graph
hello
i want to merge two xy graph and want to see both xy graph in one xy graph.
for solve this issue i have made a vi, but its not working properly according to specified.
can any one suggest me solution that what i have to do for multi xy graph plot.
thanks
Message 1 of 15
(5,294 Views)
Hi hussey,
the context help of the XY graph (terminal) shows how to achieve more than one plot in the graph…
Message 2 of 15
(5,289 Views)
hi
i have seen and read it carefully but i observe its possible only in waveform graph not in XY graph.
is it true that multi xy graph is not possible??
thanks
Message 3 of 15
(5,282 Views)
Hi hussey,
it's possible to draw more than one plot in a XY graph. Just create an array of plots!
Message 4 of 15
(5,278 Views)
i have ine file attached here could you perform it.
then it will be useful for me also.]
thanks
Message 5 of 15
(5,276 Views)
Please convert VI to LV2011!
Message 6 of 15
(5,271 Views)
have you seen my labview code?
am i forgot any major change?
please check that
thanks
Message 7 of 15
(5,270 Views)
hello
find 2011 version file.
Message 8 of 15
(5,257 Views)
Hi hussey,
don't use ExpressVIs for such a simple task:
Message 9 of 15
(5,247 Views)
Accepted by hussey
I guess the first coloumn in the excel sheet is your x values?
Message 10 of 15
(5,246 Views)
