how to read pulse from digital square wave
hi,
i have find some examples on how to measure frequency and pulse. I have difficulties in changing the ctr to port/line (I/O). Can teach me how can i modify to fit my application?
Message 11 of 23
(2,828 Views)
Accepted by topic author lim25
Using counter Only You Can Able To Measure The Frequency And Digital Events directly. So Select The Counter 1 and connect the signal to the appropriate terminal.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 12 of 23
(2,824 Views)
hi, i have manage to get the flow rate and total volume individually. However, error occurs when i try to run both programme together. eror.jpg
May i know how can i solve it ? For the above vi, i connected the output wire to pin 16 and 14.
Message 13 of 23
(2,799 Views)
hiii
      i think you must use DAQmx clear v.......which can be find by ...MeasurementI/O>>DAQmx Assistant>>DAQmx clear..
hope this helps...
thanks
do not hesitate to give kudosSmiley Happy
Message 14 of 23
(2,795 Views)
hi,sahil
I have use the Daqmx clear. same error happen.
thanks
Message 15 of 23
(2,772 Views)
hii lim ,
can you please attach the vi...
does the two loop run fine when placed different from each other..that is in different vi.?
thanks
Message 16 of 23
(2,769 Views)
Hi Lim,
    I think you are calling the same DAQmx task in the both the loops. block one while loop and execute the single while loop and check you getting the same error and do vice versa.
Balaji PK (CLA)
Message 17 of 23
(2,762 Views)
Hi sahil,
the loop run fine if place in different  vi.
Hi Baji,
I dont know how to block the loop.
Message 18 of 23
(2,754 Views)
Check this link
http://zone.ni.com/devzone/cda/tut/p/id/3684
Balaji PK (CLA)
Message 19 of 23
(2,740 Views)
Hi Baji
The loop run well if i diable one of the loops. may i know what is the second step i need to do?
Message 20 of 23
(2,734 Views)
