how to read pulse from digital square wave
You need to Merge both the loop in to a single loop.
Try this now
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 21 of 23
(1,132 Views)
hi baji,
i have tried make merge the loop, same error occur.
Message 22 of 23
(1,117 Views)
I think,You cannot able do the frequency measurement and the pulse counter using the same counter paralley. So only you getting the errror like the specific resource is reserved because both the tasks are trying the use the same resources. So you need to clear your first task before your second task starts and again you need to create the task for your fist task after the completion of the second task.That is not happening in the DAQ Assistant.Check the attached VI.
Use two counters one for frequency measurement and another for pulse counter. Connect the same signal to the both counters.
Message Edited by Baji on 11-10-2009 09:59 AM
Balaji PK (CLA)
Message 23 of 23
(1,104 Views)
