how to rectify Error 1097 in labview?
I am using call library function for calling a dll.when it is running it is showing an error 1097.  "An exception occurred within the external code called by a Call Library Function Node. The exception may have corrupted LabVIEW's memory".How this error can be solved?
(5,166 Views)
Accepted by $agar
check the following link, may give you some pointers:
http://forums.ni.com/t5/LabVIEW/Error-Code-1097-Coming-in-DLL-Calling/m-p/1847055
i used the search box at the top right of the ni website and entered 1097
hope it helps
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(5,161 Views)
Which DLL are you calling? Can you post the culprit VI for us?
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(5,156 Views)
