how to separate the each excel worksheet
Since i can't able edit and add properties node on your VI.
pls find the attached image.
But can able to run without any error in your VI.
Message 11 of 14
(938 Views)
i selected manually Excel.Application based on the below method.
Office 2013:
"C:\Program Files (x86)\Microsoft Office\Office15\EXCEL.EXE"
Office 2016:
"C:\Program Files (x86)\Microsoft Office\root\Office16\EXCEL.EXE
after run the same VI i get the following error in workbook block.
Message 12 of 14
(928 Views)
Message 13 of 14
(927 Views)
Firstly, if you're not using the Report Generation Toolkit method of obtaining the Excel._Application reference, you should probably make the application visible so you can see what's going on (like in my first example).
A quick search for information about the particular error code as suggested by the error message has found this article which suggests that a problem can arise if your computer and Excel are not configured for the same language.  Is this the case for you?
PsyenceFact
Message 14 of 14
(921 Views)
