how to tke an average of value at th 0to 15 , 16 to 30, 31 to 45, 46 to 59 mins
Use it in this manner.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 11 of 17
(703 Views)
A not so known function is this. But it is very useful. So I
Decimate (single shot) VI
Owning Palette: Signal Operation VIs
Installed With: Full Development System
Decimates the input sequence X by the decimating factor and the averaging Boolean control. Wire data to the X input to determine the polymorphic instance to use or manually select the instance.
 As I can see your interval is constant so this funtion could replace most of the coding shown in suggestions from other 😉
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 12 of 17
(697 Views)
Its not constant unfortunately. Sometimes two samples occur with the same time stamps even.
Message 13 of 17
(695 Views)
is it correct manner here is the programme,,
Message 14 of 17
(694 Views)
Here.
Message 15 of 17
(690 Views)
Dear sir,
I have Labview 2010 version , please send in competible version.,,
the sent programme is in labview 2011 version..
Message 16 of 17
(688 Views)
LV2010 version attached.
Message 17 of 17
(683 Views)
