how to tke an average of value at th 0to 15 , 16 to 30, 31 to 45, 46 to 59 mins
here is image wt i want to do and also attached with file..
Message 1 of 17
(3,625 Views)
Accepted by topic author Julian_prince
It is rather unclear to me what you want to achieve but here my 2 cent...
You have a 2D array and want to average it by the columns from index 0-15, 16-30, 31-45, 46-59.
Now what I would do is first, split the 2D array by rows so you have a 4 2D arrays. Then loop around the columns and use the "MEAN.vi" from LabVIEW to average the samples. Then merge the results.
Message 2 of 17
(3,617 Views)
Yes sir,
that is the same process which i want to apply,,
Message 3 of 17
(3,607 Views)
sir please give image form or starting of programme,,
Message 4 of 17
(3,598 Views)
Try this.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 5 of 17
(3,595 Views)
Thanks for image programme,
But this is not the exact solution which i want,
1- column is start from machine numbere  2- 32,
2-column 2 is minutes of work.
3 column 3 ih  hours of work.
Now when there is machine num  2 in column  (1),  and 0 hour in column (3 ) the take the average of column (1) for every 0-15, 16-30,31-45,46-59, according to column (2).
this procee will repeat for 0-23 hours  according to column (3).
Message 6 of 17
(3,574 Views)
The image can be dragged and dropped on to a block diagram. If this is not working, save the .png file on to your harddisk and then drag and drop it on to your block diagram.
Try this.
Message 7 of 17
(3,565 Views)
Dear sir ,
Thank you very much the programme is fine working, it gives the value whatever i deisre,
But there is little proble in the column 1 it gives machine number 2 constant, but it changes,
and it is not necessary that first value of minute  will start from  0, if start from any value so , take according to range 0-15, 16-30, 31-45, 46-59,
here i have attache my file and programme.
Message 8 of 17
(3,561 Views)
The vi gives you averages for a specific machine, you have to specify this on the front panel.
Message 9 of 17
(3,552 Views)
yes sir,
it i s not necessary every time machine number two gives the value, it varies form machine number 2- 32,
 so whatever average it is taking is perfect , but for every data machine 2 is not competeble,  ,
please sugges me so it will take average according to machine number
Message 10 of 17
(3,550 Views)
