03-15-2006 10:20 AM
03-15-2006 10:58 AM
JD,
I can make that change for you.. but didn't see your Credit Card number anywhere.. just kidding! ![]()
Seriously, if you have no experience with LabVIEW _at_all_, then you may want to get hold of someone to do this for you. Unless you feel ambitious and see this as an opportunity to learn LabVIEW. In which case you should dive into it.. look at the examples, write smaller programs, etc. LabVIEW is easy to pick up.
In any case, the VIs seem to be pretty well written (from first glance). And thanks to the descriptive icons, I can guess that the Serial instrument you're using is a Mint 3.28. Am I right?
So, once you know enough LabVIEW, the next step would be to get a manual for the communication protocol used by Mint 3.28 (or whatever instrument you're using). Then figure out how to write to its Digital outs. Maybe write a separate small program to turn the motors on and off by themsemves.
Then, figure out what other parts of the current system would be affected by turning these motors off (there must be a reason why they're running, other than to generate the noise). Finally, when all is accounted for, write to the instrument and silence those noisy buggers! ![]()
Let us know if you run into issues along the way.
Good luck!
-Khalid
03-15-2006 11:28 AM
03-15-2006 01:07 PM
