http get messy chinese characters
The reponse I get from a http request contains chinese characters,but cannot display correctly in HTTP.Get.vi
How to fix it?
I already tried to Set Headers before sending the request,but still doesn't work.
<?xml version="1.0" encoding="UTF-8"?>
<Resp><ret>绛惧悕涓嶉€氳繃.</ret></Resp>
Message 1 of 9
(3,770 Views)
The text is UTF-8, LabVIEW uses MBCS (multi byte character set). So you'd need to somehow convert the entire stream or at least the string.
See for instance this post (haven't used it myself): https://forums.ni.com/t5/LabVIEW/Will-unicode-be-supported-by-LabVIEW/m-p/225120/highlight/true#M124...
Message 2 of 9
(3,728 Views)
What's so messy about them?  They actually look quite neat and well-rendered.
Bill
CLD
(Mid-Level minion.)
Message 3 of 9
(3,719 Views)
How can you tell? He didn't show them.
Message 4 of 9
(3,710 Views)
Which VI is useful?Is there a original solution?
Now Web is popular and Labview should hand better.
Message 5 of 9
(3,677 Views)
Unicode has been a sore spot for many a LabVIEW developer.  It seems like it will never become a supported feature.  I know from experience that unless you are very careful with the undocumented Unicode features, you can really screw things up, and not only in the project that is using it, either!  That's probably why it will never be supported.
Bill
CLD
(Mid-Level minion.)
Message 6 of 9
(3,662 Views)
Fortunately LabVIEW NXG supports Unicode and stores strings internally in UTF-8.
Message 7 of 9
(3,628 Views)
That's good to know!  I guess now is the time to fix those things while NXG is still in its infancy.  🙂
Bill
CLD
(Mid-Level minion.)
Message 8 of 9
(3,624 Views)
How to deal with it in traditional Labview 2015 though?
Message 9 of 9
(3,618 Views)
