i want to split a string after every two characters into a string can somebody help me.?
You need to put your data into the strings and save the values as default.  Then save the VI and upload it.
Message 11 of 20
(3,068 Views)
Maybe  you could tell us what it is exactly that you are trying to do. It looks like you are trying to do some byte manipulation on data coming in. There might be an easier, more direct way to go about it.
Wes Pierce
Principal Engineer
Pierce Controls
Message 12 of 20
(3,065 Views)
i am trying to achieve something like this.
but the input must be in binary. so i converted it into hex and concatenated all strings.
Message 13 of 20
(3,053 Views)
Attach the VI with your data saved in it.
Why does this screenshot show only 1 string, but your VI has 4 string controls?
Message 14 of 20
(3,032 Views)
So just to clarify, you have string data as an input that has binary data, correct? So this is an ASCII representation, something like "1001100110100011" etc.? And you want to display that as individual bytes, represented in Hex?
You could simply break the string up into byte-sized elements (8-chars), convert to a binary integer, like you did, and then just display the interger as Hex. You can right click a numeric indicator, and select Visible Items»Radix. Then you can select "x" to view the number in Hex form. That might be a simpler approach.
Wes Pierce
Principal Engineer
Pierce Controls
Message 15 of 20
(3,027 Views)
i have 4 strings as input with data in binary and i want an output like in the 4*4 matrix of screenshot.
to do this first i concatenated all those strings then converted in hex then make an array having 2 characters at every index and then convert it into a matrix.
but i am only getting first row of matrix
Message 16 of 20
(3,023 Views)
Now that we have data, we can see what is wrong and can fix it.
The problem is you are taking your superlong string of 1's and 0's and converting it to a single U32 numeric, thus throwing away all the remaining data.
Convert the numbers into groups of 8 characters, and go through them in a loop to convert to U8 bytes.  The regroup from there and convert to a Hex string that represents that data.
Message 17 of 20
(3,008 Views)
You are incrementing the subset by 1, so you get overlapping segments. I don't think this is correct.
Message 18 of 20
(2,987 Views)
Here's what I would do. Modify as needed.
Message 19 of 20
(2,975 Views)
Dohh!.  You're right.  I missed i*8 going into the subset.
Message 20 of 20
(2,967 Views)
