Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
2
if no file is found, skip to the next step
Re: if no file is found, skip to the next step
TobyD
Member
03-06-2008
12:39 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
No Problem. I'm glad it worked. The important thing is that you understand what is happening in the code, so if you have questions post them back here and myself or someone else can try to answer them.
0
Kudos
Message
11
of 11
(241 Views)
Reply
2
All Forum Topics
Previous Topic
Next Topic
