image byte order
Hi, All,
I am acquiring images from Lumenera USB 2.0 camera (16-bit format). When I use the IMAQ "image to array" transformation I am getting all negative pixel values. I think the problem is related to the wrong byte order (big vs small Endian). Any idea how to fix this?
Thanks!
Message 1 of 12
(5,042 Views)
The negative pixels values are OK (thanks to NI for signed I16 type).
Read this KB article, probably its your case: 16-bit images in NI Vision
Andrey.
Message 2 of 12
(5,037 Views)
Thanks for the reply, Andrey,
I am getting an I16 image, so there is no need to do U16 to I16 conversion as in the example you showed. BTW, in this example (bottom one) type cast is wired to an exclusive or - this won't work, right due to the mismatch?
Message 3 of 12
(5,022 Views)
Accepted by femtovahan
Andrey,
I went throuhg this again, you were right, this seems to be the problem. However, in thus processed image, the image histogram looks "digitized" like a collection of delta functions, instead of being a continuous function. Any ideas why would this happen?
Thanks !
Message 4 of 12
(5,012 Views)
It might be image (for example, your camera deliver intensities with gaps) or might be required number or classes (taps) too big.
Feel differences:
Also you can post your image here and we will try to calculate histogram together.
regards,
Andrey.
Message Edited by Andrey Dmitriev on 02-10-2009 08:44 AM
Message 5 of 12
(4,992 Views)
I use histogram in 2 ways (histogram 1 and 2 on the pic). Numer of classes is 256 by default for 8-bit images. Images out of my camera are 16 bit. Now, it's a 16-bit camera with only 12 useful bits, so the number of classes should be 4096. I need to see the hist values all the way to 4096 to observe whether the camera is saturated or not - putting a smaller value for number of classses won't allow that. Do you agree? When I put large numbers for number of classes such as 4096, i do get the pattern with the gaps like in your right pic.
Message 6 of 12
(4,954 Views)
Are you sure you have an uniformly random noise image? Any real world image will not have a constant histogram over the whole range.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 7 of 12
(4,944 Views)
Rolf Kalbermatter
Rolf, do you mean the white noise? Why wouldn't the image have white noise? The histogram I am getting is not constant over the whole range, it rather has gaps, in other words, the histogram looks like a collection of delta functions.
Message 8 of 12
(4,931 Views)
Well why would it be white noise if it comes from your camera???
Rolf Kalbermatter
Message 9 of 12
(4,915 Views)
OK, let me explain the problem I am having in a different way. In the absense of any signal (laser beam imaged onto the camera) I shall be simply acquiring the background (call it noise) from the camera. The histogram of this background should be peaked at zero. Instead, I am getting a "gapped" signal like a collection of delta functions.
Message 10 of 12
(4,910 Views)
